Car door paint mark / scratch advice
Any advice for what tools, creams or solutions, etc I could use to remove the mark on car doors? Nothing major, but the scratch really irritates me. Thanks.
Scratch remover
Hello, you may want to try 3M products. They have a scratch / swirl remover that I use on my Avalon and ES300.
Dampen a Mr. Clean Magic Eraser and gently scrub the unwanted paint away. Be careful not to apply too much pressure as this can affect the paint that's supposed to be there.
Wipe Goof-Off on the paint with a clean soft dry cloth. Be sure not to rub the Goof-Off into the stain. Gently wipe and the paint should come off. Wipe the area clean with a soft clean dry cloth. Apply lacquer paint thinner to a clean, soft cloth and gently rub away the paint mark. Wipe the area dry and apply wax with a separate clean, dry cloth to the area once it is clean. Apply rubbing compound to a clean soft dry cloth and rub the stain away. Wipe the paint mark away with rubbing alcohol and a clean nonabrasive cloth. |
| All times are GMT -5. The time now is 08:13 AM. |
