Dynamic configuration
In any road condition can use the steering wheel paddles for gear changes controlled power configuration above is relatively less, an increase in the use of a point of view from the owner's intimate functions. Cash IS300 steering wheel paddles in S mode can only work, while the new IS300 is changed in any road conditions can be carried out using the steering wheel paddles gear control, for a lot of love from time to time on one of the car owners Biao is definitely a blessing. Such as paper cash dark IS300 owners immediately consult on the possibility of increasing the current model this feature, the problem remains to be answered factory.
Powertrain has not changed, still stick to this code 3GR-FE 3.0-liter V6 engine This engine uses a dual VVT-i continuously variable intake and exhaust valve timing control technology Other (3) surgery. In 3GR-FE engine and six-speed automatic transmission joint cooperation, IS30 ** Lexus IS 0 acceleration from a standstill to 100Km / h requires only 7.7 seconds, is a very good score. 2010 listing of IS 250 and IS 250C are equipped with a 2.5-liter V-6 cylinder 24-valve with dual intelligent variable valve timing control system for engines, this new engine uses a D-4 direct injection technology, design more compact, lighter, better-cylinder fuel injection, atomization more fully, to achieve better air-fuel ratio, significantly increasing the power output iS models and fuel efficiency, so that the iS 250 and iS 250C achieve excellent dynamic performance - at 6,400 r / min maximum power output of 153 kilowatts, and can in 4,800 rev / min produces 252 Nm of maximum torque,0-100km / h acceleration time of just 7.9 seconds. |
| All times are GMT -5. The time now is 09:50 AM. |
