Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Dash removal help
Old Jul 24, 2005 | 07:14 PM
s.on.gGS300's Avatar
Default Dash removal help
Hey, just got a 94 GS on friday. Turns out the old owner had a system in it but when he traded it in, he just thew in a different headunit in but never hooked it up. It's mounted and everything which leads me to believe he would have connected it if he could have. Maybe it needs a new harness or somthing, but anyways, I got the piece around the shifter out of place and the ash tray/ lighter pocket out, and also undid the 3 bolts so now the center has more lee way but is still stuck unless Im not pulling hard enough or there bolts I dont see.. But now what I dont know is if the shifter is a problem that I dont see. I wasnt able to get the top part off of it, I dont know if you need to completely remove that piece around the shifter or just get it loose enough just to get the ash tray out.
Old Jul 25, 2005 | 07:13 PM
Patrick's Avatar
Administrator
Default RE: Dash removal help
i dont know for sure, but any lexus parts dept will have a schematic showing the dash parts, and attatchments...and that should give you an idea of whats going wrong, without breaking anything!
Old Aug 17, 2005 | 09:14 PM
Thanks, already got it. Just wasn't pulling hard enough. The piece above the climate control (where the vents are) that is. I was just scared about breaking something.
Old Nov 11, 2005 | 05:05 PM
Patrick's Avatar
Administrator
i understand...believe me..
jefferies03
Mar 3, 2021 11:12 AM
nghiaho58
Mar 7, 2008 10:47 PM
Toeknee
Jul 23, 2007 11:44 AM
XXISXX
Mar 8, 2007 03:54 PM
