Starter contniously trying to start the Car.
Hi need help,
I have 1995 ES 300 and starter is contionusly running even if the ignation switch is off. I had to disconnect the battery to stop the starter. I called around some mechanich thinks that Starter needs to be replaced some said Needs new relay, Please guide me what should I do. Thanks |
RE: Starter contniously trying to start the Car.
when the internals of a starter go bad, they often dont disengage, but that is only with the key turned on...i would try the relay..it is likely much cheaper....
| All times are GMT -5. The time now is 10:08 AM. |
