| lextech |
Oct 1, 2007 09:46 PM |
RE: RX300 wierd abs problem
Wow, seen this a bunch too. Ok, the most common cause of this, I have seen, is the speed sensor "window" is out of sync. Most likely, you have recently had cv boots replaced, cv axle replaced, steering knuckle replaced, or wheel bearing replaced. When the axle is removed from the knuckle, there is a thin brass colored roundpiece of metal inserted into the knuckle where the axle rides. If you remove the speed sensor from the knuckle, there should be a clear "window" through the knuckle, through this piece of said metal, into a clear view of the "teeth" on the cv axle. This is where the speed sensor gets its signal from. If the "window" is blocked or not lined up perfectly, then the speed sensor looses singal, telling the car that the wheel is locking up and engages abs. One more cause, if you have had your cv axle itself replaced it can also be a poor quality aftermarket axle. The "teeth" on the axle are pretty precise. Some aftermarket companies do not pay near the attention to precision that Toyota or Lexus does. Hope this helps.
