Rear emblems
Hello lexus lovers.. Quick question if anyone has run Into this problem when rebadging the 2010 Gs350 rear emblems. I noticed that there was two holes after taking off the rear G & 0. Does anyone know if there are plugs the same color as the car available? Or should it just be filled by a body shop.? Also is this the same problem with the lexus badge just on the other side of the trunk before i attempt to remove it.?Never had this problem with a Older Gs and Es.
LGT Automotive.com
Apr 17, 2005 09:42 PM
