New Twist, Old Problem
Old Sep 22, 2009 | 07:38 PM
UNC1972's Avatar
Default New Twist, Old Problem
Who can tell me where under the car the sunroof front drain hole tubes terminate in a 1993 LS400? I want to have a go at a leaking sunroof from this direction to unclog the lines. Please help. You guys know this car inside and out. I know where the drain holes are---where do they end? In the tire well? Under the body? You will have my everlasting thanks.
Old Oct 9, 2009 | 05:55 AM
jackysam's Avatar
I think you should check the manual. That is the perfect thing to solve any problem.
Old Oct 19, 2009 | 01:44 AM
lovely09's Avatar
On most cars they terminate just in front of the rear wheel and just in back of the front wheel.The tubes generally run in the A Pillar and C Pillar areas and hence downward from there but if you have your manuals,check it first for assurance.
Old Oct 29, 2009 | 10:51 AM
ted27's Avatar
i think you should go for manual......you can go for this....
Old Nov 1, 2009 | 02:15 AM
  #5
bryanchan's Avatar
Yupe. Normally manual come with this information
Old Nov 28, 2009 | 01:14 PM
  #6
falUnmartturf's Avatar
Default New Twist Old Problem
hrmm... so if you have any oil blow by.. this could be a problem...
but couldnt that be cured by running an oil catch tank?
Old Dec 27, 2009 | 04:48 PM
  #7
AT or Manual tranny ??if ignit switch looks good , i can help you diagnose the problem ,,, i need to know if AT or manual manual has a starter relay,,
Old Jan 5, 2010 | 09:33 PM
  #8
Peterimagiathigiof's Avatar
Rules have been updated copied from Mavidos added rule in the Open Forum.When a thread is started, the first post must contain content relevant to the thread. A simple "title says all" will not do. If you are asking for an opinion, please provide your own. Please provide some information. Threads which the original post does not contain any relevant information will be closed and the thread creator will be given an "extra words" warning.If you have a question or problem with this, please PM me or one of the other mods of this forum. If you are creating a thread, and are curious about your original post being possibly against this rule, feel free to PM a mod to ask if its ok.
bandcstark
2
Jul 25, 2021 03:02 PM
suewerry
Feb 8, 2012 01:16 AM
as6o9bnla82
Jun 4, 2011 03:11 AM
