engine trouble!?
Old Dec 23, 2007 | 07:15 PM
jones212's Avatar
Default engine trouble!?
i have a 93 gs 300 recently its been acting crazy, i thinkh its a cracked head gasket when i start it starts boiling over in the resevoir and gets real hot but its not showing it on the reader, i also recently rplaced the thermostat, radiator and the crank shaft pulley, do you think its a crack, and would it be cheaper to replace it w a whole new engine, or to fix the crack in the head?
Old Apr 10, 2008 | 06:06 PM
sc300#0001895's Avatar
Default RE: engine trouble!?
if youve runn it hot to many times you could have blown the head.
but it sound like you didnt bleed all air out of the system.
the sensor wont read unless coolant is touching it.
other possibility is a cloged radiator
or a leak causing air to get into the system.
rbrownsc400
Jul 25, 2021 03:01 PM
Redstingray74
Jul 25, 2021 02:57 PM
triacon
Jul 22, 2021 09:21 PM
renabchin
Nov 29, 2016 08:43 PM
Bengals911
Nov 14, 2005 11:04 PM
