cabin filter
I need some assistance on how to replace the cabin filter in my 2005 ES 330. Any assistance would be appreciated.
RE: cabin filter
Hi!
It’s explained in detail in your owner’s manual and is a very easy filter to change. I have read also some car repairs and car care in Fast Lane. |
RE: cabin filter
1.open up the glove box 2.take all the salt packets straws and other junk out of it3 take a screw driver and unscrew the screw at theend of the strut (that thing that stops the door from opening all the way4. at the top left and top right hand corners of the opening to the glove box there are 2 (one on each side) turn style fastners, thay will be black so feal around 5. twist the fasters loose 6. pull in on the outer sieds of the box and pull strait out 7. at the vary back of the box is a tan door with a tab on each side, put your finger and thumb on this and pinch till it comes off 8. now you should see the filter,pull it out 9. put the new one in faceing the corect direction. and instal is the reverse, becaful puting the box back in, it can scrape the sieds of the glove conpartment and leave scratches.
