AirCon error code 24 on '07 RX350
Old Jun 7, 2021 | 03:02 PM
shustriy's Avatar
Exclamation AirCon error code 24 on '07 RX350
Hi - hopefully posting in correct spot, I'm a newbie. Trying to help my 85-year old dad fix his air con issue on his 2007 RX350 with 140k on the clock. Airconditioner blows air, but only mildly cold (ambient temp is 93F, vent temp is 55 after about 5 minutes at idle, setting is on "LO"). I can't hear the compressor kicking on/off. After a few more minutes, vent temp goes up to 75 and does not improve. I checked freon level and it seems ok (Lowside pressure is bouncing between 35 and 42, high pressure is steady at 170). No leaks detected. I see freon cycling through in the observation window near low-side pipe. Running diagnostics on display in the cabin, error code "24" shows up.
Any help or tips how to troubleshoot or repair this issue? Thank you very much and happy to join this forum!
--Joe in PA--
antman6553
Jul 22, 2021 09:44 PM
Cobraflyer
Mar 22, 2017 02:36 AM
Roy Jones
Nov 14, 2013 05:39 PM
econofour
Jan 28, 2013 12:35 PM
nanllyn
Aug 3, 2011 12:24 AM
