General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Tapping Sound/ Valve Lash
Old Dec 19, 2007 | 07:23 PM
usfstud27's Avatar
Default Tapping Sound/ Valve Lash
I have a 1994 GS300 that recently started making a tapping noise towards the rear of the engine. I believe it has to do with the valves either sticking or an adjustment issue. What could be the possible cause and solution to this problem?
Old Apr 10, 2008 | 06:03 PM
sc300#0001895's Avatar
Default RE: Tapping Sound/ Valve Lash
its either a bad fuel injector
or a bad valve guide.
feel the fuel rail and see if you feel the tapping there.
if you do most likely it the injector.
if the injector it will:
runs rich stuck open
runs lean stuck closed
bad valve train then
your looking at a timingbelt and head job
Old Dec 11, 2008 | 09:47 PM
remember the name's Avatar
if your car is high miles (80+) i have seen them leak out of the cam seal and over time couse wear on the valvetrain/cam. take it to the dealer or buy a hand held scan tool and see what codes it has.
danielle619kjx7
Mar 3, 2021 01:20 PM
03IS300_SD
Mar 3, 2021 01:10 PM
niroinc
Jan 21, 2008 09:01 AM
Donnie61
Oct 31, 2007 12:23 PM
m3amg43
Dec 22, 2005 02:46 PM
