General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
93 ES300 engine overheating
Old Jun 29, 2007 | 02:10 PM
mrventsr's Avatar
Default 93 ES300 engine overheating
I had R12 freeon added last week. It all leaked out the same day. 4 days later, the engine overheated and ruptured a the radiator hose. I replaced the hose, and added antifreeze. 1 hour later, the engine overheated again and the antifreeze was gone. The next morning I started the car to see if it would get hot and the thermostat went to hot in 4 minutes just idling. If anyone can offer advice, I'd appreciate it.
Thanks
Old Jul 27, 2007 | 11:21 PM
lexbudd's Avatar
Default RE: 93 ES300 engine overheating
there are number of possible reasons or causes of overheating: a low coolant level; a coolant leak; a defective thermostat; poor airflow through the radiator; a collapsed lower lexus radiator hose; a slipping fan clutch; an eroded or loose water pump impeller or a deffective radiator cap. it would be best to check and re-check everything. keep us informed of what other things did you notice. good luck
Old Jul 30, 2007 | 10:38 AM
rexpak's Avatar
it could possibly be the thermostat..... i had a faulty thermostat and once it was replaced no problems...
Old Jul 30, 2007 | 10:40 AM
rexpak's Avatar
what actually happened was the car would overheat.... i would turn on the heater and vent it and the car would run fine.... but once i turned the heater vent off then it would start to heat up again....i kept adding freon but it was getting annoying.... i took it in to get looked at and they told me it was the thermostat... if you are mechanically inclined you could do it yourself and by a thermostat for less then $20 i think.
halexus
Jul 29, 2021 12:05 PM
jchirita
Mar 3, 2021 12:19 PM
JohnHugill
Mar 3, 2021 10:02 AM
JosephLaubach
Apr 24, 2007 05:57 PM
suxel300
Jan 27, 2006 03:58 PM
